Old 03-29-2016, 10:00 PM   #1
Default Water system in 95 Roadtrek
What kind of plug should be in water fill port inside passenger door? What about the little hole on top. System seems to work when using tank and pump without a plug, but when connected to hose water overflows out of fill port ??Thanks for your reply
95Pop210 is offline   Reply With Quote
Old 03-29-2016, 10:46 PM   #2
peppster66's Avatar
I have a 1997, and there is a small orange plastic cap, it fits perfectly in the hole, I will try and get you a picture this evening,,,,
peppster66 is offline   Reply With Quote
Old 03-30-2016, 01:52 AM   #3
Are you just trying to fill the tank, or are you wanting to connect to city water & leave it connected? If the former, then it's normal for water to come out of the fill port when the tank is full. If you want to stay connected to city water, then you need to close the valves next to the city water connection so it won't fill the fresh water tank or hot water heater.
From the '95 Roadtrek owner's manual (page 9):
"To connect the water system to an outside source:
iii) Close the front tap at the city water connection to prevent the fresh water tank from being filled.
iv) If you vehicle is equipped with an optional water heater, close the rear tap at the city water connection to prevent water from exiting from the hot water drain system."
2003 Roadtrek 190 Popular
Gryphon is offline   Reply With Quote
Old 04-01-2016, 12:32 AM   #4
peppster66's Avatar
Hi, sorry about the late reply, been busy at work, but here are the pics of the orange plug that goes in the water fill port on the passenger side, hope it helps, thanks,,,,,, Josef,,,,
Old 04-01-2016, 12:47 AM   #5
That looks like the plug in my Roadtrek.
Old 04-04-2016, 08:16 AM   #6
Does a 2001 coach house 192tb city water work the same way,by plugging the holding water tank inlet? Won' t water still come out the little overflow hole?
ald2120 is offline   Reply With Quote
