Old 01-10-2022, 05:42 PM   #1
Default Water Pump Roadtrek 210P
Can anyone tell me what model no. to replace the water pump on a 2006 Roadtrek 210P. I know the brand is Shurflo, put can't seem to find the model no. Also, is this easy enough for us to do or would you recommend a shop to remove the old and put in the new?
Thanks!
dchristaortiz is offline   Reply With Quote
Old 01-10-2022, 06:50 PM   #2
I have a different model, so not much help
have you located the water pump?
it is running ? does it have power ?
if so,
it may have a blocked filter which is easily cleaned
after which you may want to prime it with water at level or above
the water pump in my pleasure way is behind a panel in the armoire, easily accessed and a straight forward removed and swap if needed
courage !
mike
Old 01-16-2022, 05:24 PM   #3
Default Shurflo water pump
I swapped the Shurflo Whisper King model #2093-503-413 that was stock in my 1996 Roadtrek 210 Popular for a Shurflo model #2888-422-144 that was in my trailer which I never use since I on city utilities and never looked back.
Hope this helps
Burtwood is offline   Reply With Quote
Old 01-16-2022, 11:51 PM   #4
If you can’t find it call Shurflo. They are very helpful. They use to keep track of what they sent to RoadTrek.
DwightB is offline   Reply With Quote
Old 01-17-2022, 11:47 AM   #5
This is the pump we installed in our 2004 Roadtrek. Fit perfectly.
pasusan is offline   Reply With Quote
2006 roadtrek 210p, shurflo, water pump
