Old 07-18-2020, 11:08 AM   #1
Default Water pump not working
I have a 2015 Roadtrek 170V. I replaced my kitchen faucet. Now my water pump won't come on. Any suggestions what to check out. City water connection is fine and no leaks on new faucet.
DcnChuck is offline   Reply With Quote
Old 07-18-2020, 12:05 PM   #2
Check the water pump fuse in the DC load center.
Old 07-18-2020, 05:40 PM   #3
Thanks Marko, I did check the fuse and it's fine.
Old 07-18-2020, 07:04 PM   #4
Looking further I noticed one of the 2 red wires that push in was disconnected. However, I am unable to get it to push back in. Does this connect in a specific way?
Old 07-21-2020, 10:00 PM   #5
Not sure what your pump connections look like. Can you post a photo?
JDBrown is offline   Reply With Quote
Old 07-22-2020, 02:49 AM   #6
Do you have enough water in your fresh water tank? Do you have your hot water heater bypassed?
1999 American Cruiser
2003 Club Car GS
rjf7g is offline   Reply With Quote
Old 07-26-2020, 07:11 PM   #7
Default water pump
Related to water pump problem...
My 1996 Roadtrek P210 water pump runs unexpectedly for a few seconds. No pattern or sequence. No water being used. Fuse checks ok. Anyone having this experience?
Plenty of water in fresh holding tank.
Gritty Eileen is offline   Reply With Quote
Old 07-26-2020, 07:30 PM   #8
Most likely a tiny leak somewhere bleeding off pressure until the pump turns on to replenish it.
Start by searching for a leaky faucet. Don't forget to check any outdoor fixtures.
Old 07-28-2020, 04:44 PM   #9
Default follow up 1996 Roadtrek water pump
Checked interior and exterior-no signs of leak. However, the pump had a rusted screw so I'm guessing there was a leak at some point. Decided to replace [have 140,000 miles on it] Prior to my purchase, the P210 had been sitting for a long time.
Old 07-28-2020, 05:35 PM   #10
If you have not replaced it yet, I would plug that suspected leak and see, 'hear' what happens. If this is not occuring very often, hours?, then the leak is easy to miss and might be out of sight.
Old 07-28-2020, 06:38 PM   #11
routine for us to turn off the pump switch when not using- just in case
over time we have had some plumbing connectors back off due to road rattles, no disasters ( yet) and now do pressure checks at home before and after a voyage
