Old 09-25-2020, 02:48 AM   #61
On one site I found that Valterra is using Santoprene, a derivative of EPDM, not good for many organic oils and many solvents. I doubt very much any WD40 is good for it.
https://roboworld.com/wp-content/upl...patibility.pdf
https://www.partswarehouse.com/Repla...m?Click=365719
It would be best not to use any lubricants with a valve which doesn’t need lubrication.
IIRC, Santoprene is a thermoplastic elastomer, not a cured (thermoset) one, so it is kind of like a flexible plastic and is much cheaper and easier to mold. We tried using it on some parts for some of the products we made at a company I worked at and found the properties were very poor compared to cured elastomers. It would not be my choice for a material to make sliding seals that have to hold compression as it's recovery isn't all that great and it does swell huge if it sees any oils. I think it was over 50% when it saw Superlube lubricant which is a special oil loaded with teflon.
I think we are getting close to the root cause of some of the valve issues.
Old 09-25-2020, 03:31 AM   #62
So this set of stainless steel blade, rod and NBR seals could be very good.
