Old 03-21-2013, 07:25 PM   #1
Default Wanted-Wardrobe for 08 Roadtrek 190 Versatile
Wardrobe wanted is an optional storage cabinet replacing the rear seat on driver's side, position is behind the driver's seat. This is NOT the armoire cabinet that replaces the rear seat on the passenger side. Ideally would like to find one in cherrywood to match existing.
Roadtrek says a wardrobe from the longer 210 RV does not fit, so assume the wardrobe needs to be from another 190 on the Chevy chassis.
Jim Day is offline   Reply With Quote
Old 03-22-2013, 12:57 AM   #2
Default Re: Wanted-Wardrobe for 08 Roadtrek 190 Versatile
You can try http://www.leisuretimerv.com/rvbrands/r ... fault.aspx in the US
and http://www.mobilife.on.ca/classb.html in Canada
They pop up on eBay once in a while.
Some photos here: http://www.classbforum.com/phpBB2/viewtopic.php?t=77
Old 03-22-2013, 02:21 AM   #3
They also show up regularly on the Roadtrek Chapter
http://www.roadtrekchapter.org/roadtreks-for-sale
There is one on there now from a newer 210 Versatile that may be the same as for a 190v.
Old 03-25-2013, 08:27 PM   #4
Unfortunately, Roadtrek says 2008 210 wardrobe not same as 2008 190, seems counter-intuitive since both are on same chassis, but I assume the longer 210 gets a physically larger wardrobe.
If there is anyone who DOES want a 210 wardrobe, I know of one for sale right now in San Jose, Ca. That seller sent me an excellent drawing with dimensions that I could pass on to interested parties.
Old 06-23-2013, 07:59 PM   #5
I have a 2005 190V wardrobe and the two passenger seats available.
Don't know if they fit, check with dealer first. And a microwave.
I took everything out and invested $3300 in two very customized Marine Quality cabinets.
Presently in storage locker but I have photos I can email.
I am here in Los Angeles, (949) 274-0646. Wakefield
Old 06-23-2013, 08:09 PM   #6
And the front cloverleaf table.
I needed a fulltime system so had to redesign and retrofit everything.
Old 07-16-2013, 05:55 PM   #7
Please send photos.
I'll check in with Roadtech Tech regarding compatibility of 2005 version versus 2008, they usually respond quickly and I will get back to you. Trying to match cherrywood (blonde color wood).
Hope your alterations worked well.
I took my first long trip recently & the additional cabinet space would be very useful.
Old 07-10-2015, 04:06 AM   #8
Does the 210 wardrobe fit an rs sprinter? thanks.
sholom770 is offline   Reply With Quote
