Old 11-07-2023, 01:12 AM   #1
Default Vent cover for RT adventurous 2006
Someone took our vent last night while we were out. I am trying to find a replacement but don’t even know what to look for. If anyone knows what that part is called or where I can get a replacement I would really appreciate it.
Zwillingsmama is offline   Reply With Quote
Old 11-07-2023, 01:49 AM   #2
Find your fridge manufacturer and search for lower fridge vent. Could be Dometic.https://www.ebay.com/itm/143766290220
Old 11-07-2023, 04:01 AM   #3
You should measure existing frame size and opening size. You may need to buy a whole new vent. Something, perhaps, like this:
https://www.amazon.com/dp/B00MJVT4QY...lig_dp_it&th=1
Old 11-07-2023, 09:44 PM   #4
I have a 06 Adventurous that had a Dometic Refrig. I had to replace the top vent and purchased a Dometic LS100, Ref No 9500.000958, PNC 958.2818-70 in white. Fix perfectly. Although I believe the upper one will fit, the right part number for the lower is LS200, Ref No 9500.000959, PNC 958.2819-80. I need to look for the lower too as mine is fairly loose.
I also got a Plastic primer, color coat and a gloss clearest from Automotivetouchup.com
auger is offline   Reply With Quote
Old 11-07-2023, 10:43 PM   #5
If it's the little black turn fasteners that are causing looseness, I believe that I've seen packs of them for sale on Amazon. I'm thinking of buying some and just replacing them periodically. I've also contemplated replacing them with the type of metal turn fasteners like those on water and electric door hatches.
