Old 10-30-2015, 04:31 PM   #1
Default Unsafe outlet?
I have a small Klein Tool Tester that is showing "Hot/Neu. Reverse" on a nearby outlet. Would it be safe to use this outlet for a couple of hours? Thanks in advance for any input. RT 210
Old 10-30-2015, 06:56 PM   #2
well you could for a 2 prong plug ( not a 3 as the neutral and ground are often bonded).
But I'd really suggest you trace the source of the fault and correct it.
this will protect you and the RV ( fire).
start with the source of power to the RV- test that using a meter.
if you have a twistlock the tang with the right angle is the ground- the next largest is neutral and the smaller is the hot
