Old 02-06-2020, 08:41 PM   #1
Default UHG
I have 2019 zion had it out for a drive to charge up my batteries drove for
about 3/4 hour and batteries didn't come up very far from 13.1v to 13.2v
is this normal or should it been higher. Thought I read some where that you should idle around 2500 rpm for a couple of mins before UHG starts charging
is this correct? ( I did not do this) or do I have a problem.
Thanks Joe
mira1 is offline   Reply With Quote
Old 02-07-2020, 01:49 AM   #2
You might actually be fine and just need a bit longer charging time.
I'm assuming you have the lithium package, in which case 13.1 volts may only be 40-50% charged. Depending on the size of you battery pack and the ouput of your UHG, you may need a bit more time to get 90-100% charged, which should be somewhere between 13.3-13.4 volts.
Old 02-07-2020, 05:55 PM   #3
Thanks for reply I have two banks of 200ah lithium batteries
Old 02-07-2020, 08:43 PM   #4
2500 rpms are highway speeds. High idle boost the rpms in the range of about 1200 on my Sprinter. It is not needed to charge my batteries. If I turn on the engine at normal idle I get charge input to my house batteries. It is just a good practice to according to MB to do so to burn off DEF particles. That’s why they supply a high idle option. Still the practice is to drive at highway speeds for a time after 2 hours of idling.
Old 02-13-2020, 05:24 PM   #5
How cold was it? Your batteries may not have actually started charging until heaters brought batteries up; to temp. Also, lithium draw and voltage readings are not linear: 13.2 is pretty close to "full".
Old 02-13-2020, 07:42 PM   #6
From halfway down the page here: Marine lithium batteries in operation | Nordkyn Design
Voltage reading Assessment Capacity
13.3V or more Near full Over 80%
Above 13.2V Plenty of reserve At least 70%
Below 13.15V Getting on the low side Less than 40%
Below 13.0V Definitely getting low Less than 25%
