Old 11-06-2015, 09:37 PM   #21
Is that rate just for heating, or for both heating and water heating?
Truma publishes gas consumption figures only for heating mode, but it's pretty easy to calculate the equivalent consumption for water heating:
Combi hot water capacity: 10 liters, 2.64 gal, 22.0 lbs
BTUs to heat full tank from 15degC to 40degC (140F): 1760 BTU
Propane energy content: 91,500 BTU / gal
Combi burner efficiency: 90% med / 85% high (boost mode water heating)
So in normal (med) water heating mode it will consume 0.0214 gallons of propane to completely heat the 10 liter water tank to 140F. Boost mode consumes a bit more at 0.0263 gal propane to heat the full water tank.
Stated another way, a gallon of propane will heat the water tank from cold to hot (high position) about 46 times. That's really efficient compared to traditional open-combustion RV water heaters!
rockymtnb is offline   Reply With Quote
Old 11-06-2015, 09:42 PM   #22
wincrasher's Avatar
Wow. That is so impressive. It's easy on AC too from my observations - at the lower wattage settings, I was heating to 70 degrees F and the EMS was reading 7 amps - but that included lights and the refrigerator running.
2019 Winnebago Travato GL
Old 11-07-2015, 04:50 AM   #23
Similar results here. It's (finally) getting down to freezing, and heating the coach to 68 degrees on the low watt setting was using 8 amps.
James and Stef
Follow us on our blog
https://www.thefitrv.com
thefitrv is offline   Reply With Quote
