Old 01-19-2016, 04:05 PM   #1
snicker70's Avatar
Angry Trouble filling water tank?
I have a 1993 Roadtrek and I bought last month. I'm having trouble filling the water tank. I put the adapter to the hose and put it through the hole where I'm supposed to fill the tank but it starts to immediately leak underneath the van at the top of the tank. I want to say it's leaking but I'm worried it's not going in far enough but I can't push it any further. Any suggestions?
I have tried to just put the hose in without the adapter but it appears to be hitting against what feels like a metal post. I think I'm doing something wrong. Any suggestions would be helpful. It can't be that hard but it seems that way for me. Thanks in advance for your suggestions.
snicker70 is offline   Reply With Quote
Old 01-19-2016, 07:26 PM   #2
I don;t have your model- my first question is are you sure that the tank isn't full and you are seeing water flowing from the overflow?
Old 01-19-2016, 07:35 PM   #3
snicker70's Avatar
It's a 1993 Roadtrek 210 Popular. I'm 100% sure it's empty. It's white a plastic tank under the vehicle and there's absolutely no water in it.
Old 01-19-2016, 10:50 PM   #4
If no one here has had this issue with this model, you might try some of the Roadtrek pages on Facebook. For instance:
https://www.facebook.com/groups/1676...?ref=bookmarks
This is a closed group and it can take a couple days to get approved. There is also a Roadtrek Yahoo group which has many owners of the older units, but it can take up to a month to get approved.
Sorry I can't help.
2015 Roadtrek 170
2011 LTV Libero
2004 GWV Classic Supreme
Old 01-20-2016, 10:05 PM   #5
Most likely that the water fill tube broke off or it got disconnected from the fresh tank...?
Roadtrek Agile SS: Roadtrek Mods.
https://i42.tinypic.com/dwrjpi.gif
RT.SS is offline   Reply With Quote
Old 01-20-2016, 11:29 PM   #6
Bruceper's Avatar
I assume you looked for any info in the manual?
Manual
http://www.roadtrek.com/download/1744&file_id=1745
Brochure
http://www.roadtrek.com/wp-content/u...model_year.pdf
It might not even have anything there, but it's a start.
Old 01-21-2016, 04:14 PM   #7
snicker70's Avatar
Thank you Bruce!!!
1993, filling water tank, roadtrek
