Old 12-26-2015, 02:37 AM   #1
Thumbs down Tripping Breakers
The 110 in our DIY is straightforward. Three AC outlets toggle between shore power and invertor. The inlet on the bumper is marine-grade. Everything works fine at home, even plugged into a notoriously sensitive GFI.
We have not yet been successful using shore power at a campground--we have tried 5 sites in two campgrounds. Breakers flip instantly.
Suggestions where to look for the problem?
Old 12-26-2015, 02:40 AM   #2
Are you plugging into the 15 amp or 30 amp outlets? GFCI? Which breakers trip? What inverter?
Old 12-26-2015, 12:39 PM   #3
15-amp
3 Breaker w/built-in GFI
2 Breaker w/separate GFI
All 5 tripped.
Invertor is a 750W HF.
Old 12-26-2015, 01:05 PM   #4
There was an interesting topic on the RT Yahoo Group - https://groups.yahoo.com/neo/groups/.../topics/107607 - that might give some ideas.
It sounds like your setup is like an extension cord. The odd item would be the inverter so I'd look at how you are breaking the connection to it when plugging into campground power.
I'm guessing that the breakers that are tripping are at the campground pedestal.
I can measure resistance between ground and neutral, hot and neutral and also hot and ground on a really inexpensive 1000W modified sine wave (MSW) inverter that is sitting unused on my work bench. The exact same tests on a 1000W pure sine wave (PSW) inverter sitting unused right next to it shows no continuity at all between ground and neutral, hot and neutral or hot and ground. No continuity is good in this example.
A circuit tester is handy for checking reverse polarity etc., both at home and in the van. You can even use it to check 30amp RV outlets using an adapter.
Old 12-26-2015, 01:30 PM   #5
I should add that I've used the PSW inverter in the van on an automatic transfer switch. I would not use the MSW inverter in the van on that same switch. I'd expect something to trip if lucky or smoke to come out if unlucky.
I'd use the MSW inverter in the van only if it was completely separated from the AC wiring in the van when plugged into sure power.
Old 12-26-2015, 01:39 PM   #6
Is there a way to access that info without joining yahoo?
Old 12-26-2015, 01:52 PM   #7
No, you'd have to join the group.
It was a discussion on how to wire in a MSW inverter. It got into the difference between how you end up with 110V from a MSW and a PSW inverter.
I think the conclusion was to use a 3 Pole Double Throw switch if the OP used a manual switch. That would completely separate the MSW inverter from the coach AC wiring when plugged in campground power. He hadn't purchased the inverter yet so hadn't put a meter on it to test.
Old 12-26-2015, 04:03 PM   #8
As Marko has mentioned, make sure the outlets are wired correctly with a circuit tester. You should always also check the campground outlets, they are incorrect all too often.
How many of the leads are you switching with the selector switch? If the inverter has the neutral and ground bonded, which it might or might not, you can wind up with them bonded two places once you hook up shore power, if you are just switching the hot, which is not good. The Harbor Freight inverter probably has plenty of leakage through it to trip GFCI breakers, like the cheap inverter Marko tested, if all three legs aren't switched.
First step would be to do the campground test with the inverter completely disconnected to see what happens. If that fixes it, I would do the three pole switch to switch all the lines together, with a center off for timing.
Some other points, you should have a switch on the inverter 12v side to shut it off, so you don't have a hot swap or be using power all the time when on shore power or not using the AC on inverter. You also don't want any significant loads on the inverter when you turn it on.
One thing to remember about vehicles with inverters, or generators for that matter, is that you have no earth ground like you do at home or when on shore power. That means that all AC in the van can be floating without that reference. In an extreme example, you could have 215 volts on the hot and 100 volts on the neutral (and maybe ground) and the system would work just fine. The danger comes when you get a short of some other issue (or if the neutral and ground are bonded) and that 100 volts gets to the chassis of the van. If you get between the chassis and the earth you can get zapped. Add to this that some inverters, usually the low end MSW ones, do this on purpose, putting 1/2 the voltage as a + on the hot 1/2 the voltage as a - on the neutral.
IMO, there is probably no way to make an inverter or generator in the van 100% safe, as there will always be something that could happen to put voltage on the chassis, but you can reduce the risk to very low levels. It is hard to get things really safe, when you have no idea how the inverter is wired internally or how much leakage it has.
Old 12-27-2015, 12:03 AM   #9
Thanks, Guys. I have forwarded the info to my "resident electrician" who keeps me warm at night. I will let you know how it develops.
Old 12-31-2015, 04:32 PM   #10
More info:
Inverter is putting out only 95 volts.
Inverter is not grounded.
The GFI trips even with inverter is unplugged.
An extension cord with 0.1 ohm difference between neutral and ground can trip the GFI even when the shore power breaker is off. I routinely use this same cord in the same outlet for power tools.
Old 01-01-2016, 12:21 AM   #11
How are you separating the AC connection from the inverter? Plug? Auto transfer switch? Manual switch?
Old 01-01-2016, 12:26 AM   #12
Manual switch only on the hot. DPDT. (He and I have both looked unsuccessfully for the 3PDT mentioned above.)
Old 01-01-2016, 12:51 AM   #13
I think this one might work for you.
H-Series | carlingtech.com
Old 01-01-2016, 12:55 AM   #14
There's probably enough leakage (within the inverter) to cause the campground GFCI breakers to trip but not enough to trip the breaker at home. That's my guess. I mentioned that I can measure some connectivity between ground and neutral, hot and neutral and also hot and ground on an inexpensive MSW inverter I have. No such problem with the PSW inverter's I have.
I got that PSW inverter for around $120 on sale so they've really come down in price. It's not the best but it did the job. The leakage in some MSW inverters probably gives another reason to go with PSW inverters if leaving them connected to the AC wiring in the van.
Are you using a plug into the inverter or did you hardwire it? If it's a plug then you could keep the DPDT switch but also unplug the inverter to completely break the connection. I'd keep the switch even if you unplug the inverter. I relied on my memory once to unplug an inverter and smoked it on the first trip!
(edit: I see Booster posted while I was typing)
Old 01-01-2016, 01:08 AM   #15
The inverter stuff comes up on the Yahoo Roadtrek board regularly, and it seems that the folks that have decent success use an inverter with the built in GFCI outlet and run a cord from there to whatever they need to run. The MSW units seem to do much better with the built in GFCI than downstream stuff for some reason. Of course we don't know how the guts are wired.
In this case, I think Marko is on the right track, there has to be leakage someplace, and it doesn't take much at all. One thing to remember is that is neutral and ground are bonded or leaking at all, the ground will carry current and a GFCI will trip.
Will the inverter run stuff if you dummy wire on the bench where you can get at things to measure better?
Old 01-01-2016, 01:09 AM   #16
But it trips even when the inverter is unplugged.
Old 01-01-2016, 01:16 AM   #17
"Will the inverter run stuff if you dummy wire on the bench where you can get at things to measure better?"
Don't understand.
Old 01-01-2016, 01:16 AM   #18
Have you tried a circuit tester at home and the RV?
http://www.classbforum.com/forums/f5...html#post37455
Old 01-01-2016, 01:19 AM   #19
If the van wiring is not an issue and you are having trouble because of a sensitive GFCI on the campground pedestal you could use the 30 amp outlet on the pedestal if available with a 30 to 15 adapter. Check it for correct wiring as usual. Seems pretty common to have this problem and many carry the adapter to get around it. Of course, many of these could have a van wiring issue that they will be masking instead of resolving.
Old 01-01-2016, 01:22 AM   #20
All of my inverters work. They'll all power a light bulb for example. I haven't made any changes to them at all. All are connected as per instructions. The leakage is just there in the MSW (modified sine wave inverter). No leakage in the PSW inverters.
Think of the van as a large appliance at the end of a power cord. Don't bond neutral and ground in the RV for example.
(oops, missed a post in there - thought OP was asking about the inverters on my bench)
