Old 11-18-2017, 09:14 PM   #21
Originally Posted by Mildred View Post
It's this lever that raises and lowers to allow the sofa frame to slide that I can't figure out. I'm thinking perhaps just to drill for a pin to manually lock and unlock the latch.
Those actuators are usually configured with linkage rods. Looks like there is a hole in that lever. I bet you are missing a rod that is supposed to go from the actuator to the lever. If you can figure out where the actuator was mounted, it should be obvious. For reference, I have attached a pic of how the actuator is used in the newer beds. Note that the triangular thing is a pivoting lever to increase the throw:
