Old 02-23-2016, 10:56 PM   #1
swo
Question Travato Sliding door track attachment to Vehicle
I looked at and test drove a Travato and a Zion this weekend.
One thing I noticed on both the Travato and the Zion were slight dimples in the side body right above the silver slider door track.
Initially I assumed they welded studs to the back side of the track so it could be bolted onto the body. My thought was (especially on the Travato) maybe they over tightened those "bolts" (if in fact it is attached with bolts) causing slight "dimples" in the van side sheet metal about every 9 inches in the body above the track where it attached to the vehicle.
It was noticeable from all angles on the sunny day with Travatos Gray metallic finish- less on the Zion in white.
Do you Promaster based owners see these also?
swo is offline   Reply With Quote
Old 02-24-2016, 01:05 AM   #2
wincrasher's Avatar
Nope.
2019 Winnebago Travato GL
