Old 06-04-2018, 09:16 PM   #1
Default Travato 59G fridge & rate of propane use question
Just curious if anyone has a broad estimate of how much propane might be used if I keep the fridge on propane for 12 hours while parked with no electrical? Setting off for my first road trip in my new-to-me 2017 unit tomorrow.
HawksGlide is offline   Reply With Quote
Old 06-04-2018, 10:03 PM   #2
The amount of propane used for 12 hours is negligible. It will support the fridge for days. However, most propane fridges also need 12 volts to support a regulator circuit board, igniters and the control panel, so while you can shut down the inverter, you can't completely shut off the batteries.
Old 06-04-2018, 10:52 PM   #3
warpig's Avatar
If you are a member of the Facebook group, there is a current thread about this. The consensus was that it uses very little propane.
Wannabee (hopefully someday one of following):
SC XL21 Plus (dream)| WBO 59G| Aktiv 1.0| Axion
warpig is offline   Reply With Quote
Old 06-04-2018, 11:14 PM   #4
eric1514's Avatar
In addition to the electricity required for the brains, you will use .7 amp/hr just keeping the propane on. The propane tank will last for weeks.
"Il Travato Rosso"
2015 Travato 59g
Old 06-05-2018, 12:15 AM   #5
In other words, you'll run out of battery long before you run out of propane.
Old 06-05-2018, 12:57 AM   #6
eric1514's Avatar
That’s right.
Old 06-05-2018, 01:50 AM   #7
Rough math, propane has more than 90,000 btu's per gallon divided by the 600 btu's that the burner is rated at equals more than 150 hours of actual burn time. More than a week IF it never shuts off.
Not a lot.
On TDY near Crater Lake National Park.
Old 06-11-2018, 07:06 PM   #8
We spent three months on the road this winter in Fla 1/2 those days not connected to service like water/elect. Our 20 gal tank lasted 3 months and we had some left. We have a larger cf ref in our ERA
Roadman987 is offline   Reply With Quote
