Old 06-11-2021, 05:55 AM   #1
Default Transmission/engine swap
I am looking to swap the 3.0 diesel AND transmission from the 08 Jeep Grand Cherokee into a Sprinter for the purpose of flat towing. Has this been completed or in the process?
Rrusk79 is offline   Reply With Quote
Old 06-11-2021, 12:40 PM   #2
Welcome to the forum!
I'm confused. Doesn't your Sprinter already have a 3.0L diesel and how would an engine swap (very difficult, if it can even be done) help towing? And what is it you need to tow since towing capacity is already limited by any extra weight of your class b conversion?
More info please.
Old 06-11-2021, 02:19 PM   #3
Personally, I can't imagine trying to marry in Fiat designed controls into a Mercedes designed vehicle with all the MB faults and "can't do's".
Old 06-11-2021, 04:10 PM   #4
that's ninja level and the electronic controls would be the hard part
you may also have trouble with emissions testing if that is a non-native block
mike
engine transmission swap
