Old 10-24-2020, 04:36 PM   #1
Default Towing issues
When hooked up equinox to tow and proceed to take right or left turn feels like anti skid or traction control is engaging.when straightened out no issue! Any info welcomed This is on a 2007 roadtrek sprinter chassis freight liner.2500 adventurous
Tddel is offline   Reply With Quote
Old 10-24-2020, 10:58 PM   #2
mloganusda's Avatar
Are you sure that the steering wheel is not in the locked position? If it is then your wheels are not turning in the direction you are going.
MLogan
Smyrna, TN
Old 10-24-2020, 11:13 PM   #3
What year Chevy Equinox?
Old 10-29-2020, 05:21 PM   #4
If the vehicle has posi-traction it could be that the rearend fluid needs changing. We had a class B with posi and changing fluid and adding the correct additive fixed the issue.
Frankshay is offline   Reply With Quote
