Old 03-10-2017, 03:57 AM   #1
Default Total newbie, microwave isn't working
This is the first time I've taken my RV out (any RV on my own) and plugged it in. I wanted to use the microwave but it's as if it doesn't have power. It's old and I bought it from a private party, so no dealer walk through.
I'm probably doing something wrong, I was surprised when I flipped the fuses the lights didn't go out, does that mean it's running off the battery and not the electrical connection? I did turn on the 30 amp fuse (I had a choice of 50, 30 or 20) at the power pole (whatever you call it).
Help/suggestions would be greatly appreciated. Not sure I can even replace this microwave, it's TINY!
Old 03-10-2017, 04:06 AM   #2
Model, year.
Pictures.
Old 03-10-2017, 04:34 AM   #3
This may be a 2005 PW Plateau...member has posted on that vehicle before
are you getting power to the rest of your van- the 120 volt ( like your house) outlets work?
you may have GFCI outlets near your sink(s) check that the reset buttons on these are pushed in.
you should have circuit breakers at a panel, they will have numbers on them such as 15, 20, 30...make sure each of these is in the on position
If you have a sofa , the panel may be at the base of the sofa
Old 03-10-2017, 04:50 AM   #4
Thanks for the information! I checked, I didn't have any 120v. I went back out to the shore power pole and looked at the fuses, I turned it off, not on. The microwave works fine.
I said I was a newbie, I'm making all kinds of mistakes, it's actually kind of funny. I usually do pretty well thinking things through but this is so foreign to me. Now maybe my refrigerator will get cold again, thankfully I don't have much in it that can spoil.
Yes, it's a 2005 Pleasure Way Plateau.
Thanks again for your help.
Old 03-10-2017, 06:06 AM   #5
I find that I use my microwave display to confirm IF I have 120 volt power to the van, I can look in through my side door and see it.
You may want to consider getting a tester ( or a surge device) so that you don;t hurt your van ($$$) by plugging into a bad source.
I have only seen this once but the wiring was incorrect in the "pedestal" at a campground.
https://www.amazon.com/s/ref=nb_sb_s...d=STUGWEAOAYZ0
I cannot recommend any particular product as i don't use them ( cause I use a volt meter), but you might benefit from a surge protector with indicator lights
or even these 2 devices
https://www.amazon.com/Power-Gear-3-...12ZZHZ37YY22AJ
https://www.amazon.com/Camco-55233-E...1M4RRV0SPZ7DWF
would allow you to check wiring polarity and ground are correct for $10
back to earlier GFCI- yours in probably by the sink in the bath- if it gets tripped it will likely kill outlets in the galley and outside ( my PW Lexor is wired like this) just an FYI if those outlets ever not work when you KNOW you have 120 volt power- check the GFCI reset button.
You may also want to have a look at your circuit panel so you are familiar for when you need it.
and a flashlight handy too
mike
Old 03-10-2017, 12:59 PM   #6
If you add that to your profile and signature line,
then you do not have to repeat it every time you ask questions.
Old 03-11-2017, 02:29 AM   #7
We were all newbies at one point or the other.
1999 American Cruiser
2003 Club Car GS
rjf7g is offline   Reply With Quote
Old 03-12-2017, 03:13 AM   #8
Default Thanks again
I think I'll look into a surge protector as I thought I fried something when the water pump didn't work. Later found out the interior lights weren't working either.
I hated to ask again so soon so I kept searching (I do have the manual, all 18 pages of it).
Turned out to be a breaker got tripped and they're also labeled wrong.
