Old 07-24-2017, 01:04 AM   #1
Default Tire rotation on RT Zion 2016
Wondering what mileage do you guys rotate your tires? Zion 2016 dodge. Going in for a oil change you do every oil change.
Thanks
Woodpaddler is offline   Reply With Quote
Old 07-25-2017, 10:40 PM   #2
I rotate between 5-10,000 miles and coordinate with the oil changes. I have a RT Simplicity. I run 80 psi at rear and 65 psi at front. RAM dealer recommended rotation frequently due to weight of vehicle and high air pressures.
aturner1973 is offline   Reply With Quote
Old 07-25-2017, 11:13 PM   #3
Do you drive it in the winter time?
You can rotate when you change from snow tires.
Old 07-25-2017, 11:47 PM   #4
This may shock you, but I never routinely rotate my tires. If the alignment is right and the tires balanced, it helps only a little bit and is not worth the hassle or money--especially on a dually. The extra lifetime you gain is trivial compared to the magnitude of the chore. I occasionally do an "as needed" rotation if conditions justify it.
Life is too short.
I acquired this opinion many years ago from the writings of the great John Muir (The VW mechanic, not the photographer). I have never regretted it.
Old 07-26-2017, 12:35 AM   #5
Life is too short.
Agree, with 80,000+ tires for proof, a minivan with one rotation.
