Old 08-04-2020, 03:16 AM   #1
Default Seeking Advice for Replacing Hot Water Heater/Tank in 1996 210P
Hi Guys,
New owner here. I removed the anode from my new/old Roadtrek and out came the nastiest lumps of sulfur smelling biomass. Flushed and had what appeared to be the liner of the the tank coming out (definitely not scale -- dark and brittle chunks).
There was enough rust that I decided to simply order a new Suburban SW6D tank and replace it.
It looks straightforward enough, but I'd love to hear some tips from anybody who's done this. My biggest concern is the caulking/gasket (?) on the outside. How do you deal with that?
Thanks much!
~g
gkise is offline   Reply With Quote
Old 08-04-2020, 04:16 PM   #2
Thank goodness, this is one area I've not had to tackle so I have no specific info to offer you. But have you considered what kind of plumbing connections you need to make? Mine is a newer van and I'd have to get the tools to make proper pex connections.
hot water heater, replace, roadtrek, tips
