Old 03-19-2021, 06:05 PM   #1
Default Thor Sanctuary Sprinter 4wd
Thor Motor Coach has introduced new Sanctuary Class B models based on the Sprinter 144 4wd chassis. Sanctuary 19LD and 19PD floorplans have the following standard features:
  • Sprinter 4wd 144 (short) chassis
  • Truma Combi Eco furnace & hot water
  • 19LD - Rear platform bed w/ storage underneath
  • 19PD - Power rear sofa bed w/ three seatbelts
  • 11,000 BTU air conditioner
  • Thule bike rack and side awning
  • BMPro control panel and multiplex wiring
  • Winegard Connect 2.0 combo Wifi extender/router/TV antenna
  • Onan QG 2500 LP generator, 1000 watt inverter, AGM batteries
  • Optional 800Ah lithium battery, secondary alternator, 3000w inverter replaces standard Onan generator, batteries, inverter.
Other sources have reported Thor Tranquility models with similar specs, so presumably these are marketing twin models.
rockymtnb is offline   Reply With Quote
Old 03-22-2021, 05:48 PM   #2
As expected the Thor Sanctuary and Tranquility are model twins based on the same Sprinter 144 4wd design:
  • Sanctuary 19LD = Tranquility 19L
  • Sanctuary 19PD = Tranquility 19P
An early Tranquility 19P buyer has posted a specifications sheet:
https://lh3.googleusercontent.com/pw...-no?authuser=0
Old 03-22-2021, 06:13 PM   #3
Thor Tranquility 19P MSRP Pricing:
Tranquility 19P 4WD: $118,125
Off-Road tire option: $1,744
Lithium 800Ah, alternator, 3Kw inverter option: $21,244
MSRP Total w/ tires & lithium: $141,113
For comparison Winnebago Revel 4WD has a base MSRP of $185,800 including a (smaller) 250Ah Lithium system, bump-out flares, rear lift bed, and diesel fueled heating/hot water system.
Old 03-25-2021, 06:19 PM   #4
JPMcG's Avatar
Winnebago 170X in 2012-had the same layout. Now on the market in the $6oK range
JPMcG is offline   Reply With Quote
