Old 09-25-2020, 04:45 AM   #1
Default The ZERO BREEZE A/C in a Class B RV
Has anyone considered this phenomenal product yet for use in a Class B - its the perfect size.
https://youtu.be/UfisW9u6LTI
This video is one of the most beautiful & well appointed 144 Sprinters where has integrated the Zero Breeze. This is a full van tour but at 12.25 he introduces the Zero Breeze & talks about it until 14.30 & at 19.40 he shows the external ducting.
https://youtu.be/R4O_u6c8Jnk
These Zero Breeze units won't get an entire RV Ice Cold but for many here, this might be the ideal solution
Its portable
Doesn't require shore or generator power
Can be integrated into your existing battery system
Is small & modular
Does away with big, heavy inefficient AC units
And it costs so much less ...
