Old 03-27-2021, 09:43 PM   #1
Default Switches
Where and how are you mounting your switches for accessories like fans, AC override, ETC? Pictures would be great also. Thanks
55 Nomad is offline   Reply With Quote
Old 03-27-2021, 10:20 PM   #2
Here are my locations:
1. Blusesea Control panel
2. Key light switches through electric cabinet lid
3. Main battery power and furnace and water heater
4. Each cabinet light has its own switch
5. Galley outlets, meters, and 300W Inverter switch
Old 03-27-2021, 10:51 PM   #3
Are talking about in the coach or for the chassis. For us, AC override is in the dash in a blank knockout, auxiliary cooling fans, separator control, selection switches for remoter alternator regulator, plus ammeter/voltmeter for charging coach are in the small tray at the center bottom of the dash.
Old 03-28-2021, 03:25 AM   #4
The chassis for starters. I was thinking the areas you said Booster. Can you send me a picture Booster? My lower small tray at the center bottom of the dash is open.
Old 03-28-2021, 10:34 PM   #5
Booster, did your dash have knock outs or was it a open small tray area in the center bottom of the dash. If it was open where did you get the knock out plate to seal that area off and mount switches?
Old 03-29-2021, 12:51 AM   #6
Ours was open, but now full
I am sure I have pictures on the forum someplace, I will try to find them.
On edit, found the pix in this thread on our charging upgrade as most of the stuff shown is for that. AC off override is the small red switch under the tow/haul switch.
https://www.classbforum.com/forums/f...etup-5982.html
Old 03-29-2021, 04:54 AM   #7
Thanks Booster. Do you happen to remember where you purchased that switch? I have been following along on your upgrades and you always have a professional and knowledgeable way of doing your projects. We have only had our Roadtrek a year so we have a long way to go to upgrade ours to how we want it.
Old 03-29-2021, 05:06 AM   #8
Looking again that looks like a simple on off switch and the on on switch you reference is for the other switches.
