Old 06-06-2022, 03:14 AM   #1
Default Sprinter tire pressure
What are suggested front and rear dual tire pressures for Winnebago Boldt 4X4 for both highway driving and rough non-maintained secondary roads?
Captainal is offline   Reply With Quote
Old 06-12-2022, 06:49 PM   #2
Hatteras Jim's Avatar
I think you need to start with the tires - manufacturer, model, size, maximum tire pressure and load rating. Then look at your gvw. In my sprinter (2500) running michelins, load rating "E", with maximum pressure of 80 psi, I run 75 psi in the rear and 55 in the front. With a fully loaded van, I am at my gvwr of 8500 pounds. I got my ballpark figures from a michelin tire chart I found on-line. If you have 10 people respond, you will have 10 different answers. This works for me.
Old 06-12-2022, 06:55 PM   #3
you should have a sticker from the RV manufacturer ( winnebago, not MB) on the door pillar
it should spec size, load rating and inflation for the tires
from there you can try going up or down to find a good combination of traction, handling and MPG
if you are dumping air for off road use, you may want to air up for highway use
mike
Old 06-13-2022, 12:21 AM   #4
Jim: Thanks much for the great advice! That makes total sense. My intent is to air up and down as the road conditions require. I’m taking the Sprinter to some remote areas in Idaho in July and August. I know there will be some challenging conditions there.
sprinter tire pressures
