Old 06-22-2020, 11:54 AM   #1
dan@haggertysmusic.com's Avatar
Question Sprinter 12volt Hot water
I’m looking for a 12 volt water heater, like the Duoetta Mk2, but One that uses 120, not 240v shore power. Any suggestions?
dan@haggertysmusic.com is offline   Reply With Quote
Old 06-22-2020, 04:32 PM   #2
Assuming your Class B already has a 120v to 12v converter or inverter/charger then just wire the Duoetta via its 12volt supply only. When driving it will operate off the vehicle 12v supply and when parked on shore power the converter or inverter/charger will supply the necessary 12v power.
For a higher quality marine/RV 12v water heater Whale offers a 3 gal, 12v water heater with full winter drain capability and replaceable anodes:
https://www.whalepumps.com/marine/si...rDatasheet.pdf
rockymtnb is offline   Reply With Quote
Old 06-25-2020, 08:40 PM   #3
IdleUp's Avatar
Another possibility which uses no 12 volt power or propane, is one that operates on the engines coolant. The design is straight forward, it uses a heat exchanger to heat water in the tank sort of like your heater circuit. After you turn off the engine you'll have 6 gallons of heated water. If you need additional hot water you can let the engine idle for a few minutes and it re-heats the tank again. My Europremier RV back in 94 was equipped with one of these heaters. After we stopped for the night we always had hot water without using propane. It's a great "free Heat" design!
I would check with some marine supply houses. These coolant heaters are popular for marine installations, some have a 120 volt element for when your plugged in.
Stay Safe Mike
12v water heater, sprinter 144
