Old 04-20-2017, 01:45 AM   #1
Ron
Default Spark Plug Onan Generator
Would like to change the spark plug in my Onan Generator on my 2010 RoadTrek 190 Popular, I believe the original Spark Plug is a Onan 167.0263.02.
Thinking of replacing with a Champion Spark Plug, what would the Champion Spark Plug replacement be?
Ron
Ron & Rose Cabral
New Bedford, MA
2010-Chevy/RT-190P
FMCA:303873 ~K1RRC~ RRRCRT@aol.com
Ron is offline   Reply With Quote
Old 04-20-2017, 03:18 AM   #2
gklugie's Avatar
I am not sure Onan manufactured your spark plug. I suggest you remove the plug and take it to your local auto parts store. They have cross reference charts for all manufacturers of plugs. You will definitely be able to obtain an equivalent unit.
gklugie is offline   Reply With Quote
Old 04-20-2017, 04:11 AM   #3
Ron
For the chump change involved, I would get the OEM spark plug
Onan 167-0263-02 Spark Plug KV
Old 04-21-2017, 03:51 AM   #4
I wonder if the multi-point Bosch spark plugs would be useful or not. They do look cool with the four-way sparking.
Old 04-22-2017, 12:58 AM   #5
hepcat's Avatar
I put Bosch plugs in a Honda... huge mistake. I ended up putting OEM plugs back in and the engine smoothed right out. If you've got an Onan 2800, with the hassle it is to change the plug, I'd just buy an OEM.
hepcat is offline   Reply With Quote
Old 04-22-2017, 01:09 AM   #6
For $3.10 for the OEM replacement, IMO it's case closed.
