Old 08-22-2016, 05:41 PM   #1
Default sliding door step
Is there a manual way to extend and retract the 2012 leasure time free spirit sliding door step? Or turn off the automatic retract at engine start? This is a dangerous feature if someone happens to be standing on the step at the time the engine is started.
MikeCavalle is offline   Reply With Quote
Old 08-22-2016, 05:55 PM   #2
eric1514's Avatar
It would be more dangerous if they remained on the step while the van drove off.
"Il Travato Rosso"
2015 Travato 59g
Old 08-22-2016, 06:15 PM   #3
I'm sure you could add a manual switch in series with the automatic control- you'd probably want a status light so you don;t drive with the step out and whack it off )
I think this is more an issue of everyone being aware of each other at departure time.
mike
Old 08-23-2016, 01:10 AM   #4
Good advise
Old 08-23-2016, 03:24 AM   #5
Chances are if they're standing on the step, the sliding door is open. Couldn't you add a switch to the sliding door preventing the step from retracting when the door is open?
WJones is offline   Reply With Quote
