Old 05-05-2019, 12:36 AM   #1
Default Sink strainer
I'm considering replacing our sink with a Dometic SNG 4133 sink. However, it seems to use a syphon as pictured below. Would I be able to fit a standard RV strainer?
By the way, what are the standards for RV strainers?
2019 Roadtrek Simplicity SRT
Old 05-05-2019, 05:47 AM   #2
I have the round SMEV sink with, what I consider, a standard drain as you posted. Perhaps this link can help you - https://pantherrvproducts.com/fresh-water/sinks-drains/
I suggest calling the Panther RV store (no association) to find out which drain outlet will fit both, your plumbing and desired SMEV/Dometic sink. I called them a few times and they were always helpful.
