Old 06-12-2016, 06:35 PM   #1
Default simple plumbing question
95 Pleasureway. Under the sink, coming off of the water pump,is a clear plastic 1/4" hose attached to a ballcock and ending in thin air. Should this be attached or is it a vent of some kind? Should the valve be open or closed?
Thanks,
Bob W
banjerbob is offline   Reply With Quote
Old 06-12-2016, 06:58 PM   #2
Thanks,
Bob W
It might have gone to a filtered water faucet, or it could be an air bleed for getting the pump to prime or for gravity draining of the system.
Old 06-12-2016, 09:32 PM   #3
If it's on the input side of the water pump, and it's a T valve, I would think it was used to feed plumbing antifreeze into the system for winterizing. They would simply put the pipe in a jug of antifreeze, turn the valve, and run the pump.
William
WJones is offline   Reply With Quote
