01-24-2019, 05:09 PM
Sewer Hose for Winnebago Era 170X
I am new to this 170X class b and just discovered my sewer hose (from the macerator pump) is split in 3 places. I want to replace it with a longer one. Does anyone know what size (ID and OD) and type of hose this is? It needs to be fairly flexible to store and If there is a better grade, (this one died in only 2 years) I would like to install it. Thanks
08-25-2019, 01:11 AM
Late reply but the hose is a 1" inside diameter hose. The hose in my 2017 170X did the same thing; it was 2-3 years old. Hose was very brittle. I purchased a new one on Amazon https://www.amazon.com/Clean-Dump-CD...web_8496891011 and replaced it.
10-21-2019, 05:03 AM
I've been searching for a replacement for my newly acquired 2018 Era B. Hose broke in 2 places when I pulled it out! Camping World had no clue!
10-22-2019, 01:30 PM
WOW.. that's very premature fails on the 2017 and 2018 posts
I purchased my RV in May 2017.... and I experienced a crack in my dump hose with the macerator pump.
All I can say is, get the OEM parts or have it done professionally..... A neighbor who said he could do it for less really botched the job and I had to get it completely redone the correct way.....A really good RV shop that does repair work can get this all done for you. It's a dirty job and you want it done right....
If you take it to a professional, it will cost you about $750.
Be very careful pulling the hose out of the channel. And, I've only heard that Camping World is not a good place to get this serviced.... your mileage will vary.
These are precisely the things that are NOT COVERED under any warranty or maintenance contract...
Good luck.
10-22-2019, 01:36 PM
Roadtrek used poor quality hoses, shown by the OP's and many other's early failures, so IMO, using the same hose again would be not a great choice.
Many of us have switched to the Sani-con super flexible hose and really have had great success with them. Easy to use, easy to store, not fragile.
https://www.amazon.com/Thetford-7042.../dp/B003DIU4C0
10-22-2019, 02:33 PM
Interesting comment...
My Roadtrek hose was the original hose that failed in the 6 and 1/2 year... not one or two.....
It was brittle....in the one year since being replaced, it works perfectly....
I don't know why you would say that they're inferior....
As for storage, the hose is permanently attached to my RV and is in it's own channel under the rig..
10-22-2019, 02:46 PM
We have heard about bad hoses on Roadtrek macerators for years, most failing early, like ours did on our 07 190P. Do you even know if yours was the original, as you bought the van used? I think you will find most everyone here understands why it is often stated that the hose setup was inferior. We have had the Sani-con for nearly a decade and it still works like new, and very easy to use.
You, yourself, just stated earlier in this discussion to be
which certainly would indicate fragility to me.
10-22-2019, 04:22 PM
"We have heard about bad hoses on Roadtrek macerators for years, most failing early, like ours did on our 07 190P."
Roadtrek Adventuous RS1, this has been understood for more than 10 years.
10-22-2019, 07:45 PM
That is Camping World! Ron
Ron J. Moore
'15 RT210P
10-23-2019, 03:47 AM
Reason I said that....
You, yourself, just stated earlier in this discussion to be which certainly would indicate fragility to me.
Yes, I said that, but, it's because if you are not careful you can catch the hose on the access door panel which is metal and rip the hose.
Besides, it's always a good idea to take out and replace gently...it's a plastic hose...
As far as I know, it was the original hose... We'll see how it goes from here. My replacement hose is fine and it's been on my RV for over a year now. No problems.
10-24-2019, 10:54 AM
OP has a Winnebago Era.
