Old 05-23-2011, 03:47 PM   #1
Default Running propane
The question is: Do you leave your propane valve open while traveling? What I am referring to is leaving the propane valve open, and NOT running any appliances. Such as the refrigerator. We normally run the frig on battery while traveling, but when we stop, we'll turn it on propane. We will open the propane valve while stopped and then turn it off when we begin our travels. It would be easier to just leave it open and turn the frig off and on from the inside, rather than monkeying around with the propane valve all the time. This would also leave the lines filled with propane, making it easier to start the frig or burners. Currently, we need to start the burners each time to get gas through the lines before getting the frig started. Any thoughts on this as a safety issue?
Jim & Darlene, & Pickles our Teddy Bear
2013 RT Adventurous...aka Roada
Wisconsin Dells WI...Water park capital of the world[/color]
yizit is offline   Reply With Quote
Old 05-23-2011, 06:26 PM   #2
Default Re: Running propane
Personally I'm paranoid about such things and would probably turn it off so that the system is dry while in motion.
Malysoun is offline   Reply With Quote
Old 05-24-2011, 12:02 AM   #3
Off is safer. No chance of forgetting when you stop for gas.
In my B+ and C I kept it on for the fridge (no 12v option). I haven't tried the fridge on 12v in my new to me B yet. If it maintains the fridge temp I think I'll drive with the propane shut off,
Here's a poll:
http://www.classbforum.com/phpBB2/vi...php?f=25&t=620
Results still show approx 50/50 on or off.
