SAM -
This from Amazon's BOT (US varient);
The product information shows this TV has 10 watts of speaker output power and averages around 40 watts of power consumption. A customer review also mentions it draws 19 watts, which is low for RV use.
The SPECS show 65 Watts listed as power requirement. But it does require 110V (again US). The UK Amazon has a number of these inverters. I guess you are running through an inverter - not directly from solar.
Let me offer a few educated guesses about your situation. I'll use my 3C's to try and explain what I would look at.
1. Consumption. Inverters have an efficiency rating. Could be as low as 85%. That suggests you'd probably need a 100 Watt inverter just for the Smart TV. Inverters create heat (inefficiency) and may be powering other devices simultaneously. A large inverter and additional "users" could explain the power consumption. If you have access to a smaller inverter and ran it from your solar array/charging system to the TV only, perhaps might have better luck. Something to consider. [I see some on the UK A>Z, but you'd want to bypass the battery operated cigarette lighter if it is wired to the battery bank to test.]
2. Charging. Solar panels have an efficiency rating as well as a number of factors regarding installation that can cause reduced output; cooling, age, mounting, connections, etc.. These issues could explain reduced charging. I understand you are trying to run an inverter from the solar panels, which can be done. But to keep from discharging the battery, there needs to be sufficient capacity in the solar array to account for these inefficiencies. The panels charging the electronic devices and running interior lights would be 12 sources - yes? Are these wired directly to the solar charging system?
3. Capacity. If the charging output is less than the consumption, then the battery bank will be used to run the TV. I am assuming the wiring is from solar to battery to TV (inverter, etc.) until it is depeleted. Age, size and type of battery bank can be factors to review.
For over 30 years we had solar panels on our sailboat. The only shading we ever experienced was cloud cover, sail shadow, or when in storage/maintenance "on the hard." In our RT we now seek shade, and have chosen to forgo the addition of solar to our rig. Its addition would slightly increase weight and drag (increasing fuel consumption). And, when underway, the large alternator obviates any additonal charging solar panels could provide.
I've tried to give a broad overview/simple breakdown for you to consider when trouble shooting. Best of luck.
BTW - Photos and diagrams of the setup help, and are always appreciated!
Cheers - Jim
