Old 02-22-2022, 08:59 PM   #1
Default RT 210 water heater door panel
I lost or someone lifted the door panel for my water heater on my 2008 roadtrek 210 popular.the # on the inside unit are SW 6 D so I went to Surburban PP rv parts but the unit I think they recommend is Suburban 6255ACW,, ( maybe the wrong color ) But the bigger problem is this measures 15.58 x 15.26 my unit measures 15 x 15.. So the door panel 12 3/8 x 12 3/8 probably won't fit ??? Any ideas?
Thanks
Michae
mangomike is offline   Reply With Quote
Old 02-23-2022, 04:14 AM   #2
Unfortunately, when I went to my Suburban Installation & Operation Manual I found part numbers for nearly everything but the cover door. On p. 3 of the attached .pdf, it shows the "Radius Cover Door" in the diagram but I can't find dimensions or a part number. Sorry.
File Type: pdf SW6D-SW6DE-SW6DM-SW6DEM-Installation.pdf (1.27 MB, 3 views)
Old 02-24-2022, 03:13 AM   #3
Check with Amazon, they have had them earlier.
Ron J. Moore
'15 RT210P
Old 02-24-2022, 01:08 PM   #4
This one from Amazon worked for my Roadtrek, though you need to pay attention to where the latch in the door is for your model year to make sure it will line up correctly (look at the comments on Amazon):
https://www.amazon.com/gp/product/B002UC4SIG
Old 03-03-2022, 01:35 AM   #5
Default Got this one if you need it
If you have the flush mount trim with the square insert I have one left over from my recent water heater replacement. Here is a picture, it came out upsidown but you should get the idea. Let me know if you want it.
fwdanielson is offline   Reply With Quote
Old 03-04-2022, 05:09 PM   #6
Thanks for your generous offer.
We took a chance and ordered Suburban 6255APW Polar White Water Heater kit from Amazon
the measurements on the Amazon site were wrong , So on arrival it fit.
So, thanks again
Michael
