Old 05-05-2024, 04:32 PM   #1
Question RS Adventerous Roadtrek Rear couch seatbelt
We just bought a 2015 Roadtrek RS Adventerous and the rear bench seat folds down to make into a bed. It came with seat belts, but they aren't bolted down and I can't find anywhere I can bolt them down in the back. The shoulder belts are installed on the sides, but the clip side of the belts were just sitting in the back "basement" when we purchased it. Can anyone tell me where these are supposed to go? Can't find anything in either the Mercedes or Roadtrek Manuals.
Thanks.
Clineomine is offline   Reply With Quote
Old 05-06-2024, 01:43 AM   #2
Mine are bolted to the floor under the couch. (See red arrows)
2015 Roadtrek RS Adventurous
HubFlyer is offline   Reply With Quote
Old 05-06-2024, 03:03 AM   #3
Default Thank you
Thank you. Apparently they were never installed because there are no holes in the plastic cover. But I do see an indentation where I may be able to pop out the hole to expose the threads for the bolts below.
cpnorton is offline   Reply With Quote
Old 05-14-2024, 02:27 AM   #4
Default Hip level seatbelts not attached in rear seat RS Adventurous
/Users/wallyrowley/Desktop/IMG_1800.JPG.inetloc
/Users/wallyrowley/Desktop/IMG_1801.JPG
Apologies re the dusty condition of the reargate storage area where the noted belts are secured in our 2010/2011 RS Adventurous. You are correct that there are knock out plastic floor panel components which should reveal threaded openings for bolting in the hip level seat belt ends. Just completed our 27th Ontario-Alberta-Ontario migratory trip with this vehicle hence the dust. Detailing will occur soon. Good luck finding the attachment points.
bonnecavesman is offline   Reply With Quote
Old 06-19-2024, 12:47 PM   #5
Thanks.
The brochure for your Roadtrek states it has seating for 2. My Roadtrek had seating for 4 but I removed one seat and replaced with a drawer unit. I keep the bench as a bed with a memory foam topper on it. I don't want anyone's Bum on my bed anyway.
In my Roadtrek, there is a label by the rear bench that states the rear seats are not to be occupied while vehicle is in motion. I guess I can remove the seatbelts back there. Joe
jojobafanzi is offline   Reply With Quote
Old 06-19-2024, 12:57 PM   #6
Thanks Joe.
adventurous, roadtrek, seatbelts, sofa bed
