Old 09-16-2020, 03:33 PM   #1
Default Roof Caulking
Our Roadtrek SS Agile is 5 years old and while washing the van recently I noticed the caulking / sealant around the exhaust fan looked worn and brittle. See attached picture. How often do others replace the caulking and which product is recommended? I’m trying to practice proactive maintenance but perhaps I’m overreacting as we have not had any leakage issues. Thanks!
Steve
File Type: jpeg 3E37C606-5592-489A-AA09-90E7BA1A04E8.jpeg (23.8 KB, 30 views)
sdunn4 is offline   Reply With Quote
Old 09-16-2020, 07:00 PM   #2
If you clean it really well you may be able to put some self-leveling Dicor sealant over the existing sealant.
Old 09-24-2020, 12:33 AM   #3
Thanks! I followed your advice and cleaned the surface well prior to sealing over with Dicor self leveling sealant.
Old 09-24-2020, 12:05 PM   #4
I use Sikaflex 221. Roof seals can go bad very quickly, especially in the subtropics. The Dicor stuff doesn't seem to stand up as well here (Texas Gulf Coast).
Old 09-24-2020, 08:38 PM   #5
mloganusda's Avatar
You can use Ethernalbond tape for sealing where Dicor is used. It comes in several widths and I have used it before. Once you apply and roll on top to activate the glue, it is near impossible to remove and seals for many years.
MLogan
Smyrna, TN
