Old 09-07-2021, 10:51 PM   #1
Default Roadtrek Window Replacement
While rolling down the road about 50mph on a very dark night, about 9pm, we heard a loud bang as if something hit the top of our 2008 Roadktrek 210. Upon stopping to check, I found the upper middle window (above the windshield) on our RT was shattered. It was still in place so I applied packing tape to the inside, and the next morning when I had access to a ladder I taped the outside of the glass to hold things in place and keep the rain out. A nearby glass place informed me that they could replace it with laminate glass, but weren't able to cut tempered glass and would have to find a source to order a replacement piece (it's trapezoid shaped). Wasn't able to find any info/advice in the forum posts, and no glass available to fit mine from mobile life rv, or dkhardware. Did send an email to van life and waiting for a response.
Any suggestions? Preference is to replace with tempered glass, but I guess I may have to settle for laminate.
Still have no idea was caused the shattering - saw no rocks or debris coming at us, no feathers or other marks on the glass, and no trees overhead.
Thanks in advance!
bwatters60 is offline   Reply With Quote
Old 09-09-2021, 01:46 AM   #2
I would take them up on the laminate glass offer. Just an opinion.
Old 09-09-2021, 12:29 PM   #3
[QUOTE=hbn7hj;132007]I would take them up on the laminate glass offer. Just an opinion.[/QUOTE
You might want to check with a street rod builder type shop as I think that windshields and side glass is cut down for chop top cars. What I have heard but never seen or confirmed is that they tape them off and use a sandblaster of some sort. You might get lucky.
Old 09-19-2021, 10:49 PM   #4
ballbraindogs's Avatar
I have a 2000 Pleasure Way Excel TD. My friend, who was driving in front of me, kicked up a rock and "BAM" broke the little window above the drivers side.
I was able to have a regular vehicle window place replace the window. He came to the house and made a template and had the glass cut. He then came back to install it. It wasn't perfect because the original glass had a bit of a curve to it but, it was good enough.
It lasted a few years before it started to leak. Then, I found an RV window place near Denver called "Resolution Glass". All they do is RVs. They were able to reseal the window and I am good to go now.
ballbraindogs is offline   Reply With Quote
Old 10-18-2021, 05:36 PM   #5
Thanks to all for the suggestions. I considered them all. Since this turned into a DIY project, I documented it as I've done with all my issues and upgrades. This helps me remember what I did for future reference! Since it's a little long and includes pictures, rather than write it up in a post, I'm attaching a PDF. Maybe this will help someone else. Thanks again to all for your suggestions. Bruce
File Type: pdf Class B Forum Update_Glass Replacement.pdf (529.1 KB, 14 views)
