Originally Posted by booster
It looks like there is harness extension that just ends going down. The "4" arrow to the connector goes through it on the driver side. Perhaps that is the trailer hitch pigtail, if the factory put one in. Can't think of where else it would go. If it is maybe the module will be near it.
booster - I think I've found it!
But to get to that part... Remove the upper trim piece:
![](https://www.classbforum.com/forums/attachment.php?attachmentid=14665&stc=1&d=1712934015)
The hardest part was forcing myself to put some muscle into it to release the clips. Had the correct tool - but my "Force Nothing" moto was flashing...
There are only 2 nuts to remove on that piece.
And to pull the lamp housing to get to the bulb sockets there are 3 nuts. All take a 10mm socket - with maybe a squirt of PB Blaster too.
With access to the bulbs - I swapped them and proved to myself the wiring was OK. Then replaced the original bulb in its position- Voila! It works. Years of surface corrosion I suspect. A bit of emory paper, some contact cleaner - and I'm off to the store to get 4 Switchback LEDs and replace the lot. Both sides.
May your experience be as rewarding!
Cheers - Jim
