Old 03-14-2022, 10:28 PM   #1
Default Roadtrek Spare Tire Carrier
I have a 2013 Roadtrek Chevy 190P. It has the Roadtrek spare tire carrier, not the EZlift model. It works fine but make loud squeaking noises going up or down. Should I be lubricating the cable and/or the wheels? If it needs to be lubed can I just spray it with something or what should I use?
Thanking you in advance for any help with this.
Keep on having fun!
Langton
2013 Roadtrek 190 Popular
Langton is offline   Reply With Quote
Old 03-14-2022, 11:25 PM   #2
Keep on having fun!
Langton
IIRC, we have heard about squeaks and it was usually the spring in it's guide tube under the van. Spaying some lube into the tube may take care of it, but something the lubricates well and stays put.
Old 03-14-2022, 11:26 PM   #3
I have that same setup in my ‘15 210; they will sound off until you spray, grease them, etc. I have used Spray White Lithium Grease and it works. I had the E-Z Lift on my ‘05, Roadtrek should have taken that on…..works so much easier.
Ron J. Moore
'15 RT210P
Old 03-14-2022, 11:42 PM   #4
Thank you, I will give it a spray.
