Old 11-17-2020, 07:42 PM   #1
Default Roadtrek seat removal
Hi all, we have a 1997 Roadtrek Popular (love it). The driver's seat is pretty worn out but the passenger seat is still in good shape (I often use it for my daily driver). I'd like to swap the seats. Does anyone know how to remove the seats? I see the big nut on the swivel post centered underneath the seat. Is it that simple?
Thanks for any help.
Ramble is offline   Reply With Quote
Old 11-18-2020, 12:36 AM   #2
Yep, that simple.
Old 11-22-2020, 01:25 AM   #3
Thanks, I'll get on it this week and let you know how it went.
Old 11-22-2020, 10:15 PM   #4
First you have to remove the carter pin that runs thru the nut and then it comes off
msroads is offline   Reply With Quote
Old 11-23-2020, 01:07 AM   #5
The arm rests will be wrong
gpdc is offline   Reply With Quote
Old 11-23-2020, 01:18 AM   #6
The seats are identical, why will the armrests be wrong?
Old 11-23-2020, 01:40 AM   #7
Default seat swap
because they are going to be on opposite sides
Scottie409 is offline   Reply With Quote
Old 11-23-2020, 01:43 AM   #8
hhhmmm.....we have a 200 Versatile....technically an "A" I think....and (I just went out & looked) we've arm rests only on the INSIDE of each seat.....the seats are adjustable forward & back, the back rest can tilt rearward & they swivel 360 (kinda)......I've rebuilt the drivers' (mine) seat a couple of times,latest revision added thrust & rotational ball bearings....adjusted to my liking with the nut reached underneath the seat riser......so, we're not really apples to apples here...my bad
Old 11-23-2020, 02:09 AM   #9
Yeah, we have armrests on both sides of the seats. Want to thank everyone for helping out. One more question before I do this job, after I get the nut off, do I have to rotate the seat to a specific position before I can lift it off?
Old 02-24-2021, 01:06 AM   #10
Finally got around to this seat swap. It went smooth. Removed the 3/4 in. nut and lifted the seat off. Two big washers fell out. Reinstalling after the swap was also easy. Hardest part was getting hands into tight space to position washers and nut. Had to get the wife to help out with her smaller hands and arms. Together we got her done.
Thanks again everyone for your help.
removal, roadtrek 190 popular, seat
