Old 08-07-2023, 08:23 PM   #1
Default Roadtrek rubber side molding
Does anyone know where I can buy a piece of the rubber side molding that runs down the side of the van? It fits in a groove and covers the screw holes for the fiberglass ground effects. It measure 1" wide by 1/4" high and its rounded. If anyone knows a source to buy this I'd appreciate knowing.
Thanks
2013 Roadtrek 170 Versatile
jwd673 is offline   Reply With Quote
Old 08-07-2023, 09:57 PM   #2
Check Steele Rubber products and compare the end profile and measurements against the products in the catalog- many manufacturers use Steele
Old 08-09-2023, 01:58 PM   #3
Thanks for your reply Mike. I did try Steele before I posted this. I even sent them a picture of the profile. They do not carry this shape. Thanks again.
Old 08-13-2023, 05:04 PM   #4
We used this on our 92D190P Roadtrek.
https://www.amazon.com/Insert-Moldin...over%2BRV&th=1
Kobieta is offline   Reply With Quote
Old 08-13-2023, 07:08 PM   #5
Thanks I will check it out. Appreciate it.
Old 08-15-2023, 10:23 PM   #6
You might also try a marine supply, like west marine.com. Boats use similar moldings for rub rails.
dashton72 is offline   Reply With Quote
