Old 08-18-2023, 04:04 PM   #1
Default Roadtrek remote control panel?
I’m installing a RV QG 2800 into my 2006 Chevy Versatile 210 which has never had a generator installed. I need to acquire a remote starter control panel. The problem I’m finding is that RT pre installed the wiring but I have only 4 colored wires and most wiring diagrams show 5 wires to the panel. The colored wires installed are 1 yellow with 1 connector, 1 Brown with 1 connector, 1 Red with 2 connectors, and 1 black with 3 connectors. I was going to use a 0300-5332 panel. Any suggestions for a panel to use with their existing wiring? Thanks
Swishewk is offline   Reply With Quote
Old 08-19-2023, 06:38 PM   #2
Buy the panel that looks identical to the one pictured in the owners manual. You will figure out the extra wire when you put it all together. I believe there are only four wires to the generator.
