Old 05-31-2022, 05:45 AM   #1
Default Roadtrek Propane hose leak
Good Day!
I have a 2012 Roadtrek Versatile and the main propane hose between the shut off valve and the regulator leaks. In the owners manual the schematic of the system shows it as: 1/2” IDx 9” Rubber (POL)
Anyone have an idea as to where to find a replacement hose?
If I cannot find one then I will need to have a local propane shop make it. I suspect though that it is an off the shelf item if one knows where to look! Thanks in advance for sharing your collective wisdom!
popstartoo is offline   Reply With Quote
Old 05-31-2022, 12:38 PM   #2
DaveBad's Avatar
I purchased my new hoses here when I refurbished my tank. They make them per order so if you contact them they can make any length/size hose you need.
https://prairiebearingshop.com/produ...g/propane-gas/
DaveBad is offline   Reply With Quote
Old 05-31-2022, 05:34 PM   #3
Default Thanks
Thanks for that suggestion. The owners manual lists YSN Imports as the supplier of the tank. When I did an internet search for that company it came up with Flame King as the associated business. I sent them an Email yesterday and we will see if I get a reply. Thanks again!
Old 06-05-2022, 06:58 PM   #4
Take your old hoses to a welding supply shop. They will make exact replicas
Thevon is offline   Reply With Quote
Old 06-05-2022, 08:26 PM   #5
eric1514's Avatar
I took an old hose off and took it to a propane supply business. They built a quality hose dirt cheap while I waited.
"Il Travato Rosso"
2015 Travato 59g
Old 06-06-2022, 12:14 PM   #6
Many propane hoses have only a 5-year warranty life. We had a local shop duplicate ours after learning about several Class Bs of our approximate model year that had developed leaks, including a same-year rig owned by a close friend. We did the installation ourselves.
Two corresponding blog posts with more details on the hoses and DIY instructions, in case they are of use to you:
ADVISORY - LP GAS HOSES ON T1N AIRSTREAM INTERSTATES
and
REPLACING THE LP FLEX LINES IN AN AIRSTREAM INTERSTATE
Old 06-18-2022, 08:32 PM   #7
Default Update
Thanks for the suggestions.
The hose that was leaking was from valve to the regulator between the bumper and tow hitch. With patience and a several different angle wrenches I removed it, went to a local propane delivery company, had a duplicate made and then replaced it. Now if there are not leaks in all the surrounding fittings it should be good to go. My initial test using a gas sniffer still detected a leak, it is a confined area with two regulators that might be bleeding off pressure since I just filled the tank. Fingers crossed!
