Old 02-28-2019, 06:48 PM   #1
Default Roadtrek Paint Code?
I need the paint code for 2005 Roadtrek 210 Popular tan ground effects kit. My Roadtrek is white on top and tan on the ABS plastic ground effects. My battery box fell out of my Roadtrek on the rough dirt road to the RTR in Quartzsite. No one to call at Roadtrek. Thanks mrvista
mrvista is offline   Reply With Quote
Old 02-28-2019, 06:54 PM   #2
I know the codes for an 05 190P. I'll go find it, if anyone can confirm that the 210 and 190 are the same.
Old 02-28-2019, 07:21 PM   #3
The 190 is a Ford color DD 4282 Mocha Frost Metallic
Old 02-28-2019, 07:52 PM   #4
Thank you very much.
Old 03-10-2019, 07:46 PM   #5
Default Tan trim paint 2005 Chevy Roadtrek
For what it may be worth, the paint shops I have used show me a variety paint chips or samples from the original paint manufacturer for the same paint code. I t6hought a color code was a color code but apparently not.
Over time several body shops have suggested that to get a good color match try to stay with the same brand of paint because additional variations show up in trying to mix paint to a color code across different brands.
I have found that paint shops seem to want to use their color determining machine to give their paint vendor a color code that works with that paint suppliers brand of paint.
Having said all that If you only want spray cans of Duplicolor, the Mocha Frost works has worked reasonably well for me on our 2004 Chevy RT 190 Popular (as long as I prep the surface reasonably carefully)
BJ 2004 & 2013 RT 190 Pops Fl Keys
Bjones7788 is offline   Reply With Quote
Old 03-11-2019, 05:07 AM   #6
CaDreamin's Avatar
Normally your paint codes will be found in a sticker inside the passenger side door jamb. There are other codes inside the driver’s side door jamb as well but those are not the paint codes.
WA519F (GM Galaxy Silver) is my code, down at the bottom.
File Type: jpg 33F4F85B-E23D-4B72-BCEF-F29612F55C85.jpg (211.0 KB, 44 views)
Old 03-11-2019, 12:44 PM   #7
I can't think of any reason GM would have a Ford color on the sticker that roadtrek used, not GM.
