Old 06-15-2021, 06:33 PM   #1
Default Roadtrek LPG Monitor Panel
The LPG indicator on the monitor panel always says 100% full but the dial gauge on the tank is working and currently shows 1/2 full. Anyone have ideas on what I can check?
Thanks.
06C210V
Swishewk is offline   Reply With Quote
Old 06-16-2021, 01:11 AM   #2
If the tank gauge has a sender like this on it, then maybe that is the problem, but I do not know how you would check it: https://www.amazon.com/Manchester-Ta...dp/B003D3WPGS/
Old 06-18-2021, 04:47 PM   #3
Thank you. I purchased the Manchester gauge and installed it any everything is working properly again.
Old 06-18-2021, 05:31 PM   #4
Thanks for the followup. It's always good to hear how things end, especially when it ends in success. Glad RT-NY's suggested part worked.
roadtrek propane monitor
