Old 03-09-2019, 01:43 PM   #1
Default Roadtrek Adventurous RS - diesel alde
Does anyone have detailed instructions on how to de-winterize a Roadtrek with a diesel alde system.
I understand general concepts and techniques. What I need are specific details on the correct valve positions for the alde. These valves are located under the side cushion on the driver side rear of the coach. There may be others I am not aware of.
Manual from Roadtrek did not deal with this unit ( it discussed wabasto and suburban )
CAS3 is offline   Reply With Quote
Old 03-09-2019, 01:45 PM   #2
If no one responds, you could try a manual a year or two newer/older looking for you solution.
Old 03-09-2019, 03:59 PM   #3
If you do Facebook, join the Roadtrek & Hymer Owners Group and I think you will get the info you need from other owners...
Old 03-24-2019, 05:43 PM   #4
From my 2017 CS Owners Manual.
Old 03-24-2019, 05:46 PM   #5
From 2017 CS Manual,.
Old 03-25-2019, 02:13 PM   #6
ponti33602's Avatar
Thx - this is handy.....did not see this in mine. I am having some Alde challenges as well and created a post on the RT Owners group......CAS3....not sure if anyone may respond to something that could assist you too?
Regards,
Bob
2017 RT Agile SS
ponti33602 is offline   Reply With Quote
Old 03-25-2019, 02:31 PM   #7
Cold line (into water heater) and hot line (out of water heater) should be open. Valve connecting the two lines should be closed. Reset freeze valve (turn valve and set and release spring-operated trip mechanism).
alde, diesel, roadtrek
