Old 03-20-2021, 07:28 PM   #1
Default Roadtrek Adventurer RS Width
Hello.
All the data I could find on the width of the 2014 Roadtrek Adventure RS shows the width as 6'8" without mirrors. Not sure what good that measurement is.
I wanted to built a carport and I have limited room. Anyone know how wide these units are with the mirrors out? Do the mirrors fold-in on this model/year? What would be the dimensions with the mirrors folded in if they do?
I haven't received the vehicle yet...just looking ahead.
Thanks
ovsa is offline   Reply With Quote
Old 03-20-2021, 07:49 PM   #2
I'm picking up my 2015 on Tuesday. If no one answers by then I will be sure to post the measurements.
2015 Roadtrek RS Adventurous
HubFlyer is offline   Reply With Quote
Old 03-21-2021, 12:00 AM   #3
Jon in AZ's Avatar
Overall width not including mirrors is industry standard for all motor vehicles under DOT and state regulations, so that’s what’s always given. 80” is a break point on width: extra clearance lights are required over 80”.
Hopefully someone will be along shortly with the number you need. On my Chevy Roadtrek the mirrors fold quite close.The widest part for storage parking is actually the rocker panel storage pods.
2014 Roadtrek 190 Popular
2008 Scamp 13
Old 03-21-2021, 01:32 AM   #4
The mirrors measure out to out a little over 95" on my drawings. I would round that up to 96" which is 8 ft. Folded in I doubt you could get under 7 ft. More likely 7'-2".
Old 03-23-2021, 10:02 PM   #5
I got 97" with a hand tape measure. Davydd is probably right, but it's definitely no more that 97" on my 2015.
Old 03-23-2021, 11:05 PM   #6
Thanks.
..so do the mirrors fold in? Is that standard on those models?
Old 03-25-2021, 07:55 PM   #7
Hi. I have a 2013 Roadtrek Agile and both the mirrors do fold. I’m not home now to measure with the mirrors folded but can check later. Enjoy!
Linda
lgiles2 is offline   Reply With Quote
Old 03-25-2021, 08:02 PM   #8
Thank you !
Old 03-25-2021, 08:24 PM   #9
ovsa, What are your maximum limits?
Old 03-25-2021, 08:52 PM   #10
106 inches.
Consider i still have to open the door to get out.
Old 03-25-2021, 10:19 PM   #11
I plug our rig into shore power when stored - a Roadtrek 190 - and need the lower storage compartment cracked ajar for the cable. This is an easy spot to crunch on ours when entering or exiting tight storage. Padding on the inside edges of the enclosure supports might be worth considering - ours are concrete so gotta pad them.
BJ
Bjones7788 is offline   Reply With Quote
Old 03-25-2021, 10:35 PM   #12
They do have a bit of a "hinge" type seam but I couldn't get them to fold in and didn't want to force them.
Old 03-26-2021, 02:02 AM   #13
OVSA, considering that you only have 106" maximum, even at 80" vehicle width you won't be able to open any swing door. Could you perhaps strategically place a door opening on the garage sidewalls adjacent to your driver side door?
Jim
2001 RoadTrek 170, Dodge 2500 5.2L V8
ra2jim is offline   Reply With Quote
