Old 07-25-2019, 06:44 AM   #1
Default Roadtrek AC drainage pan
Our 2010 Roadtrek 210 Popular developed a leak inside. Turned out it the pan under the AC unit was cracked. My dealer repaired it temporarily with some roof tape, but it has started leaking again. Best solution would be to replace the pan, but I don't know where to find one. The AC is a Dometic Cool Cat with heat pump. Any suggestions?
rscrogg is offline   Reply With Quote
Old 07-25-2019, 11:37 AM   #2
Is the pan fiberglass or plastic? If fiberglass then a fiberglass boat repair shop van probably repair it. They may be able to repair plastic also.
roadtrek ac pan
