Old 11-09-2017, 12:57 AM   #1
Default Roadtrek 200 Plumbing
I have a 1999 RT200 (Chevy chassis) which I purchased used a couple years ago. There have always been some issues with the plumbing that are strange. For instance when it is connected to shore water the hot and cold faucets are reversed from when the pump is used.
Are there any plumbing diagrams for this unit? In particular I am curious about the 3 lines going down through the floor by the hot water heater. The fresh water holding tank line is easy to identify. The other 2 are not as clear. it seems like when shore water is connected it comes through the line that is attached to the hot water heater outlet (hence the reversal of hot and cold). This doesn't seem right.
I have a feeling a previous owner did some modifications and got things messed up. I would like to fix this.
Thank you.
drober05 is offline   Reply With Quote
Old 11-09-2017, 02:26 AM   #2
jmai's Avatar
If you have three lines and you already know where one goes, that only leaves the other two. Since you are dealing with a hot and cold, try reversing them. Easy to reverse if it doesn't solve the problem. Try the simple things first.
Joe
jmai is offline   Reply With Quote
Old 06-21-2019, 04:28 AM   #3
Does anyone on the forums have a picture of their RT200 Versatile plumbing under the driver's side rear seat? This is where the pump and water heater are located. How many lines come up through the floor in there? Mine has only 3 but I think there should be 4.
