Old 08-29-2021, 08:45 PM   #1
Default Roadtrek 200 Cable TV Connection
I have a 1998 Roadtrek 200 (Chevy Chassis). Over the years I have solved many mysteries about this rather poorly documented vehicle. However there is one remaining and I am hoping someone here might know the answer.
Inside the TV cabinet there is an antenna connection box labeled Antenna and Cable TV (photo attached). I know that the antenna is internal to the roof of the unit and we have used it on occasion. The mystery is what the Cable TV connection goes to (I verified there is coax connected inside the plate). I have looked all over the RV in all the underneath storage and am unable to find any coax connection. Does anyone have a similar unit that knows where the connection is (or is supposed to be)?
drober05 is offline   Reply With Quote
Old 08-29-2021, 10:55 PM   #2
I'm sure you'll get a reponse from an R/T owner
on my pleasure way the shorepower, water and coax for campground cable are all under the same cover
mike
Old 08-30-2021, 06:13 AM   #3
Don’t have your year or Model but the cable connection is behind the lid of an approximately 2” square gray plastic box on the driver’s side rear underneath a hinged panel.
Old 09-05-2021, 06:03 PM   #4
On my 2004 RT 200P, my cable in port is located on the driver side cargo bay on the left side of the cargo bay door frame.
k1hog is offline   Reply With Quote
Old 09-06-2021, 01:36 AM   #5
TheMatrix's Avatar
When we owned a 2007 RT 170, it was inside driver's side cargo storage area. Hope that helps.
TheMatrix is offline   Reply With Quote
