Originally Posted by KurtFranz
yeah - i have a part time job touching up all of the new spots using the rattle can after a trip where the paint peels off. I clean up all of the loose paint, sand it up a bit, mask it off and hit it with the paint -no primer. Holding up quite well as it has been tested by full hose pressure three feet away when washing it Pretty soon the entire van will have a nice dull white finish, but it wont peel any more. The protection is the important part and I am not sinking a bunch of money into a 22 year old van......
Totally agree, and would not say it is wrong at all.
To put it all in perspective, about 4 years ago I did the bodywork and paint on my 96 Buick Roadmaster wagon. It is a big car at 18' long but not high like a van. I did not paint the roof as it had been done sometime in the past, probably from hail damage. I had quite a bit of light to moderate bodywork to do on both front fenders, one door and one quarterpanel. I am slow at getting stuff straight so took a long time. I used PPG second line catalyzed urethane base and clear Omni paint which is still very good paint. I also two toned it so lots of masking. Primer was PPG epoxy which has no second line. I welded up 150 molding holes that were for the removed phony woodgrain and used waterproof filler on all of it. It took me on full winter of working on it probably 20-30 hours a week and I had around $2000 in materials. It is not show quality, but high driver quality as that was the goal. Probably around $9-10 at a body shop, though.
Body and paint work is very expensive unless you can find a bodyman or hotrodder that does side work in their garage, and that is a quite good option. Check out of the main city areas where neighbors won't complain about paint smells and welding as that is where most of it is done now.
