Old 12-08-2016, 06:45 PM   #1
Default Rialta Louvred Window Seal
I am trying to locate the vinyl window seal located at both side rear jalousie windows. This is the horizontal seal on the exterior (J-Seal) between the top fixed glass and the moveable crank out glass panel. I have a 1999 Rialta HD. Winnebago no longer has the part. The window is an Atwood and the part number is: 132-01596. Winnebago's number is: 100322-01-702. This will enable you to see the diagrams for yourself.
The problem is that these shrink and mine is almost an inch too short. The rain comes into that slot and dribbles down the sidewall inside. I have researched and called so many places with no luck. You Rialta owners must have similar problems of shrinkage? It is vinyl so at least it doesn't crack.
My only solution at this point is to find a LARGER Atwood window and carefully remove the longer piece and cut it to fit my Rialta.
Thanks and hope someone knows where to get one!
Paul
CGAZ Paul is offline   Reply With Quote
